Armageddon - Help Please!
Posted by: Christopher on 06 February 2003
I would really apprecaite some advice on LP12s & Armageddons. I am about to buy a new LP12, and have the opportunity to buy a newish Armageddon. My question is (are) how do I fit the Armageddon, just it just plug in somewhere? Do I need to specify a particular LP12 to suit the Armageddon? Do I need to specify the basic power supply, or can I order without?
Sorry if these are really basic questions, I reall yhave no idea! Any help would be greatly appreciated.
Many thanks
1)
Posted on: 06 February 2003 by jpk73
First get the Armageddon and then give the parts (connection board etc.) to the dealer you will buy the LP12 from. He will fit the Armageddon mod to your LP12. That's what I did when I bought my newish Armageddon and my new LP12...
- Jun
Posted on: 06 February 2003 by Christopher
So does this mean I can buy an LP12 without the basic power supply? (I believe that this has to be bought separately at extra cost)
Posted on: 06 February 2003 by kan man
Yes - You don't need the basic power supply if you have an Armageddon.
Steve
