Mini Vacuum Cleaner
Posted by: raymond on 18 September 2002
Hello all. I'm trying to locate a mini vacuum cleaner to enable me to hoover my equipment " hi-fi gear". Any ideas?
Regards, Raymond.
Regards, Raymond.
Posted on: 18 September 2002 by Bob McC
Maplins sell 'em
Posted on: 18 September 2002 by Manu
Why a mini, my MIELE and my wife's PANASONIC do it perfectly well.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Emmanuel
Posted on: 19 September 2002 by raymond
Emmanuel
Hello Manu, I find it extremly difficult to push the dyson hose under my turntable....etc. I need a very small hand held vacuum cleaner that has a very small hose for reaching parts other vacuum fail to reach. Regards, Raymond.
[This message was edited by raymond on THURSDAY 19 September 2002 at 14:21.]
Posted on: 19 September 2002 by NeilM
I bought a Turbo Tiger (from Stowe of Cheltenham I think, you know one of those trashy lists of stuff that you didn't think you really needed).
I went for this one because it was mains powered. It seems to do the job very well and comes with quite a few tools to access small places.
Posted on: 19 September 2002 by Adrian F.
Miele does additional tools and tool-sets not only for their own vacuum cleaners. I use the micro-hose included in my car-clean set to clean the front plates with the buttons, the cd-compartment of the CDS2, keyboards and other small technical stuff. There is also a separate micro-clean set... I also like the "SUB10-Universalbürste" to clean the tops of my hifi equipment and the racks without scratching the surfaces.
Take a look at www.miele.de (sorry, details only german).
Then you go under Unsere Produkte \ Haus-/Einbaugeräte \ Staubsauger \ Zubehör \ Zubehör-Sets + Sonstiges Zubehör
happy listening
Adrian
happy listening
Adrian
Posted on: 24 September 2002 by raymond
Regards, Raymond.
Thanks to you all for your valid comments.
Regards, Ray.
