Av2 -No signal in center and back
Posted by: Eplemac on 03 December 2008
Hey! Received my AV2 about a month or two a ago, and I was told by the reseller that it was completely new, so i guess it has the latest firmware...
The av2 is connected to two nap 250 cb (one to the center and one to the front channel) and two nap 90/3 for the surround channels.
The sources are a sony bdp-s550 and a Oppo DV-983hd.
The problem is that there is only sound coming out the front speakers, and not the surround/rear/center channels. The DTS led is lighted in the display as well...
Ive dobbelchecked all the connection, cables, and the different poweramps -they all work on the front channel... So Ive narrowed it down to being the Av2...
Anyone have Any idea? Should I just send it back to Naim? -Dont like the idea of spending the Christmasholiday without the naim systemFrown
Posted on: 03 December 2008 by Adam Meredith
I presume that you have spent quite some time following the Users Manual and are connected to your sources via a suitable digital cable and have set up these inputs to receive digital signals?
Posted on: 03 December 2008 by Eplemac
Yes! It worked perfect until yesterday... Came home, and nothing worked. Had it powered off for app. 24 hours, and when I turned it back on, only the front speakers were working...
Posted on: 04 December 2008 by AV@naim
1) check firmware rev here
http://forums.naim-audio.com/eve/forums/a/tpc/f/3452929996/m/4372966617
2) check setup settings have not reset themselves back to defaults, i.e. are C/Surr on in the setup menu??
