Internal shot of Nait 5
Posted by: Justin on 08 July 2003
My kingdom for an internal shot of a Nait 5. The shots on Naim Audio Short guide are too close up, and only show the main PCB. If you have one, please post here or email to juddson1@msn.com
Judd
juddson1@msn.com
Judd
juddson1@msn.com
Posted on: 08 July 2003 by Mike Sae
Why do you want to see the inside of things before buying them?
Actually, I always pop the hood of a car I'm interested in buying so I can say to myself confidently, "yup, it's a motor".
Dangerously close to making a car/hi-fi analogy,
mike.
mike.
Posted on: 08 July 2003 by Justin
Good question. I'd like to see what it looks like compared to the 150 on the inside. Just curious. I think looking on the inside gives you an idea of what you are getting.
Consider the flatcap and the snaps. On the used market, they are something like $350 and $150 respectively. After seeing the inside of the flatcap, I could spend less on the snaps with confidence.
Obviously, you have to use this sort of reasoning responsibly.
Judd
Judd
Posted on: 08 July 2003 by Stuart M
It's nearly always depressing looking inside to find how little is in there.
But then you switch it on
To err is human; to really foul it up requires a computer.
Posted on: 09 July 2003 by Richard Dane
A bit small but hopefully this will do.
Posted on: 09 July 2003 by Greg Beatty
I bought ALL THAT!!!
I'm used to the empty box syndrome - seems that not the case with the Nait 5.
Gee, I wonder how it would sound if they split it into two boxes. Oh, wait...
- GregB
Insert Witty Signature Line Here
- GregB
Posted on: 09 July 2003 by Justin
Well,
Now that looks lovely. Thanks
Judd
Judd
Posted on: 09 July 2003 by colinjay
great post!
...94.5% of statistics are made up...
Well,
I decided to have a go at a 112/150 combination principally because the price was right. This gear will be replacing a 72/140 combination for a number of reasons, not least of which is the remote control and a hankering to experience some of the new Naim sound. What's more, my replacement gear is only 1 year old and so i don't have to worry about recapping anytime soon.
But why, you might ask, did I do this combo rather than a nait 5? Good question. The combo (used from a dealer) only cost me about $300 more than a used Nait 5 from a dealer. So, I thought it was a no-brainer. Also, my gut tells me that the 150 will be a very worthwhile improvement over the amplifier section of the Nait 5 (though, my gut also tells me that the pre-amp section of the Nait 5 is arguably about the same as that found in the 112 (point me straight on this if I am wrong)). So, on balance I though the combo would be the better way to go. Can always add hicaps in the future.
Unfortunately, I'll have to gerry-rig a phono section from a nac 42/snaps until I can coble together enough $$$ for a stageline. Any reason why taking it out of the tape-loop of the 42 should be avoided. I see none--but I might build the boards into a seperate box for good measure anyway.
I'll let everybody know what I think of this combo vis-a-vis my 72/140 combo when I get a chance.
Judd
Judd
Posted on: 09 July 2003 by Mike Sae
Congrats on your purchase!
I listen to the 112/150 (with obligatory FC2
) whenever I'm at the dealers and I think it's awesome. No reservations whatsoever.
Let us know when you get a FC2. Or Hicap. Then the stageline. And a Hicap for that.
Then new speakers.
Enjoy!
Then new speakers.
Enjoy!
