av set up alternative for naca5 for rear
Posted by: Himat on 17 April 2003
new to naim
just bought av2 napv175 naca5 for the front
ruark cl20/cl15
next puchase nap150 and m&k k4 for rear
need alternative to naca5 for rear as it will be difficult to hide the cable of that size plus it will be quite long runs 15+mtrs
Posted on: 17 April 2003 by Phil Sparks
when I put a nait and rega kytes in my bedroom with a link to the main system downstairs I had the same issue - didn't really want fat white or black Nac a5 snaking round the bedroom. My naim dealer recommended QED aniversary silver (not sure if this is exactly the name but it's something like this). It was A5 -ish price and is transparent with silver (obviously) conductors so is much less obtrusive. Sounds fine in the bedroom, although we don't do much in the way of critical listening in there.
Alternatively QED 75 (if they still make it) is probably fine and pretty cheap.
PHil
Posted on: 17 April 2003 by pac
You may also want to look at Chord's Rumour or Odessey for this application.
Posted on: 17 April 2003 by Greg Beatty
...of running the signal at line level to an amp at the back of the room?
- GregB
Insert Witty Signature Line Here
Posted on: 19 April 2003 by Himat
thank you for your replys
i have to look at stands for this to go on
