Jason Hector
Posted by: count.d on 05 November 2001
How long did they take to run in?
Are they good?
Any advice on placement, etc...
Thanks for ridiculing my decision to research non-Naim amplification in previous threads!!!!!!
Alex.
I'm getting an HX1.2 to go with my L100 this week.
So nerrrr ;o)
Alex
Stewart
Alex
I discussed Obelisk upgrade mods with Shahinian and followed their recommendation (total cost about $1,000). When I specifically discussed the castor issue I was told that they were for convenience only; they did not believe there to be sonic differences, except perhaps relating to speaker-floor clearance in certain situations. With respect to the latter (because of bass 'bloatiness' and proximity of the bass speaker to my carpeted, suspended floor) I decided to try some SB1s. I opted against castors because Shahinian said they looked a bit odd on the flange-less older cabinet. As I mentioned, I am very pleased with the (visual and auditory) result -- regardless of its precise aetiology.
Stewart
