SNAICS
Posted by: Ade Archer on 14 March 2003
Hi,
Do pre-amps come with SNAICS or is it power amps/supplies only
Ade
Posted on: 14 March 2003 by syd
It appears that the Power amps and PSUs come with the cables unless someone knows different.
Yours in Music
Syd
Posted on: 16 March 2003 by Martin Payne
Power amps come with a cable that terminates in a 4 pin DIN at the preamp end (but may have either DIN or XLR at the NAP end).
Mostly, power supplies come with one SNAIC-5 cable. Exceptions:-
SNAPS came with a SNAIC-4 cable.
XPS, 52PS & CDPS comes/came with a burndy.
SuperCap doesn't come with any cables at all, as you may need one or two SNAIC-5s, or a 52 burndy and a SNAIC-5, or a SNAXO burndy.
N.B. The FlatCap2 can use two SNAIC-5s, but only comes with one.
The SNAXO comes with a SNAIC-4 to connect the preamp PS to the SNAXO PS.
The Stageline comes with a SNAIC-5.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
