AE / SN / Linn Classik Q
Posted by: Right Wing on 01 February 2010
Quick query.
I have an imac downstairs, I am wanting to (temporarily) send audio wirelessly upstairs to feed a Linn classik. Then in a few weeks a supernait.
Can someone please tell me what I need to be able to do so. Also, can a HiFace be used in such a setup?
Thank you
Posted on: 01 February 2010 by winkyincanada
Get an Airport Express. Use the analogue out into your Classik. When you get the SuperNait, use SPDIF optical from the AE to your SuperNait.
The Airport Express is setup as a part of your WiFi network (you don't actually need a sparate router, but your iMac must have WiFi), and it then appears as a speaker option in iTunes. Select it and you're away.
HiFace wouldn't work as the AE doesn't have a USB out to drive it. It also isn't required.
Posted on: 02 February 2010 by Right Wing
Winky
Thank you for your time in replying.
Is it possible to hook up a lavry dac as well ? - AE-DAC-Classik ?
Thank you.
Posted on: 02 February 2010 by Occean
Yes any dac will work in this way
