HDX Service Pack 9 Update Available.
Posted by: Phil Harris on 02 February 2009
Service Pack 9 is now available for the HDX hard disc player, this service pack contains all previous packs plus a number of additional potential bug fixes.
Naim Audio recommends that any HDX units running software prior to Service Pack 9 should be updated to Service Pack 9 as a matter of course.
You can check your current system software revision from the "System" -> "System Status" page. (The overall version should read as 1.4x xxx where "x xxx" denotes the sub iteration of software.)
If you need to obtain an update disc then you should contact your retailer directly.
Phil Harris
