Naim DA. Voltage
Posted by: JYOW on 26 January 2010
Did I read correctly from that the naim dac supports both 100-120 and 220-240v?
If so it'd be a welcoming change
Posted on: 26 January 2010 by Klout10
I don't think so.
Michel
Posted on: 26 January 2010 by pcstockton
One or the other right??????
Posted on: 26 January 2010 by winkyincanada
Always been a little bit confusing. Naim is avaliable in either voltage, and that is what the specs say, but they don't switch on the fly. They can be converted back and forth without much hassle or cost, though.
Anyone want to start a debate about whether the 240V units sound better/worse than the 110V units?
Posted on: 26 January 2010 by u5227470736789439
Is there anywhere in the world where this could be done with commercial consumer grade mains electricity of both 110 and 220 volts in a blind test in one single room?
Otherwise the point is probably moot!
Suggestion and failed memory will have a big impact on the reliability of the results.
ATB from George
I kind of agree George. Hard to do a comparison. Here in Canada, you can apparently access a phase-inverted 110V signal that you can add to the other line to give a line-to-line symmetric 220V. Not sure how this would work with 220V hifi gear, though.
It's not obvious to me which voltage would be better, if either. There are likely much more important variables like RFI interference and stability.
Would that be legal in a domestic home!
Winker ATB from George
Posted on: 27 January 2010 by winkyincanada
I believe it is legal. Obviously needs to be set up by qualified and authorised personnel.
Posted on: 27 January 2010 by Richard Dane
Yup, the final listening room next to "Goods Out" at Naim. This is where every piece is plugged-in and listened to before being cleaned, wrapped and packed. Obviously it caters for both 230V and 115V (and 100V too). For obvious reasons, the factory has to be multi-voltage throughout final production, test, service and R&D.
Posted on: 27 January 2010 by JYOW
Confirmed that the Naim DAC is not switchable between 100-120 to 200-220
Posted on: 29 January 2010 by Frank Abela
AFAIK, you need different transformers for the different voltages.
Switched mode power supplies, on the other hand, can be set at the flick of a switch - a definite advantage, if only they sounded as good...
