HDX 24x7?
Posted by: T38.45 on 03 June 2009
Hi,
do you power-on your HDX 24x7?
Regards ralf
Posted on: 03 June 2009 by Patrick F
I keep mine on all the time. The best solution is to.
Put the "computer side" on a UPS and use an external supply for the analog and keep it powered unless there is a storm or on vacation of course.
Posted on: 03 June 2009 by T38.45
Tx Patrick!
Posted on: 03 June 2009 by gone
I keep my 555PS on 24/7 but power down the HDX, as it seems to make my NAS very hot. Not sure I've worked out why but it does seem to keep scanning the network for a long time. I don't know if the 555PS keeps the DAC & analog bits alive even if the computer bit is powered down, but it doesn't seem to make any difference to the sound.
Which is excellent by the way
Posted on: 27 June 2009 by Klout10
I'd like to keep mine on all the time, but it gets so warm (warmer than my SuperNait)...
Therefore, I switch it into standby when not in use.
Michel
