Netshare with HDX
Posted by: hnik on 27 August 2010
I have some FLAC files in my computer (PC running Vista). HDX plays the files nicely when the folder is OK. However, I messed up with one folder, trying to change the order of tracks by using the Windows Explorer. Then in HDX Netshare, this one file appears as 4 albums with crazy order of tracks. Even when I completely erased the problem folder, and downloaded again the entire album, HDX still persists in thinking that the earlier 4 crazy folders exist.
My question is essentially what to do. But I do not know how to delete some "albums" from Netshare. NaimDesktop does not allow me to delete any netshare folders. So I did the only thing I can do: to delete the folder from my computer, but HDX still thinks it exists.
Hiroshi
Posted on: 28 August 2010 by Klout10
Did you try a reboot of the HDX to solve your problem?
Michel
