Naim Interconnects
Posted by: GeraldHK on 27 April 2007
Hi - ive got my first naim equipment arriving tomorrow so obviously very excited (christmas coming early this year!) I've got av2 ,nap300 and cdx2 coming and keeping my tag 5 channel till i can afford a 145 for the centre and a 200 for the rears. Ive been using chord signature interconnects on my tag in the past and been very happy with them but now i see its din plugs only or is that not the case? Do you guys keep the naims din plugs or is there something better? appreciate some advice
Posted on: 27 April 2007 by markusp
Hi Gerald - unfortunately it is DIN only with the AV2. In fact, you will probably need to order some new DIN to RCA cables for your set up even before you can hook everything up since it is the only way you will be able to use your Tag amp. Of course, you will be fine hooking up your NAP300 right away and enjoy terrific 2 channel sound (or 2.1 channel sound since you can hook up your sub straight away with a standard rca interconnect).
Congrats on the new gear! I've owned the AV2 for the past two weeks and absolutely love it.
Posted on: 27 April 2007 by GeraldHK
thanks mark - maybe i could the signatures reterminated , will email chord and see what they say
