Can anybody advise on wireless networking?
Posted by: TomK on 16 November 2008
I've just bought a Panasonic BD35 Blu Ray player. It has a standard 10Base-T connection for BD-Live connection. Can anybody tell me what I need to connect to the BD player to make it talk to my wireless router? I've found a few wireless Ethernet bridges but they all have USB connections and are therefore not what I need.
Any advice most gratefully received.
Thanks.
Posted on: 16 November 2008 by Exiled Highlander
Something like the D-Link DWL-G810 Ethernet - Wireless adaptor would be what you need....I would add a hyperlink to it but I'm not sure what the rules are about linking to products and Google will work just fine.
Edit: It may be discontinued but a Google search for "Ethernet wireless adaptor" or similar seems to work.
Jim
Posted on: 16 November 2008 by TomK
Thanks Jim but most of what turns up seems to be USB based and that's not what I'm after. If you can be a bit more specific I'd be extremely grateful.
Tom.
Tom
Try a LINKSYS WET54G 54Mbps Wireless-G Ethernet Bridge or similar bridge from manufacturer of your choice. Some stuff on the AVS Forum (Panasonic owners section I think). Any bridge that takes 10/100 wired ethernet in/out and bridges to wireless will do I believe.
BTW, the BD35 is $250 in the US if you search around...amazing price.
Jim
Posted on: 17 November 2008 by TomK
Thanks Jim. Just ordered this from an Amazon seller. This was one of the first gadgets I found but for some reason I managed to convince myself it wasn't what I needed. Fingers crossed!
Tom.
