n-Sat Brackets
Posted by: HRC99 on 26 March 2007
I can't really find anything on the n-Brackets at all. I've tried googling to no avail.
I'm looking at adding a pair of n-Sats to my system but need a bracket for them that will swivel around 20 degrees.
Any ideas guys?
Posted on: 26 March 2007 by Adam Meredith
The n-Brackets are fixed, with no swivel.
Posted on: 27 March 2007 by HRC99
Thanks Adam. The first picture I've seen of them. I'm not sure if there are (or you can recommend) any brackets that would swivel.
The room set up just won't allow anything other than wall mounting and requires the speakers to swivel.
For anyone interested you can see it all here!
Posted on: 28 March 2007 by Nick_S
Fix a tapered block of wood to the wall and then the N-sat bracket --- it is designed to decouple the speaker like the special stand.
Nick
Posted on: 28 March 2007 by HRC99
Nick
It would really need to be "proper" bracket; as the cables are chased into the walls and I'm not sure there'd be enough speaker cable coming out of the wall to fit off a block.
Nice idea though! Smile
