UPS advice
Posted by: Billy Rubin on 29 June 2010
Intending to go for ReadyNAS Duo with 2 x 1TB Seagate Barracuda drives to serve HDX-SD.
Can anyone give advice RE UPS for the ReadyNAS.
Posted on: 29 June 2010 by pcstockton
Have it shipped overnight so you can start playing with it asap.
Posted on: 29 June 2010 by Billy Rubin
Ok, Pat. I guess you having a slow morning with the windows.
UPS = uninterruptible power supply
Posted on: 29 June 2010 by james n
Big Grin Big Grin
Posted on: 29 June 2010 by Guido Fawkes
APC Back UPS ES8 Power Saving Outlet 00VA
Posted on: 29 June 2010 by nap-ster
I use an APC ES8 too. You can connect it to the ReadyNAS Duo so that the ReadyNAS monitors the UPS status and will shut itself down if the battery drops to a certain level.
There's also a handy app for the iPhone/Touch which will give you the ReadyNAS status called NASTouch.
Thanks!
