Headline question
Posted by: kevinrt on 23 March 2002
I have just taken delivery of a Headline and am very pleased on first listening. I've hooked it up to the no.3 (tape) DIN on my Nait 5 but I'm not certain of how to set the controls on the Nait 5.
I've tried it with CD source selected, the main volume turned down (or mute selected) and volume adjusted on the Headline. However I've also found it works if I set the CD running then select the tape Mon button.
I can also listen to CD through the headphones and have the TV playing through the speakers via the AV input. Is it advisable to have 2 sources running through the amp at the same time?
Can anyone offer any advice/comments on how to get the best out of the Headline please.
Also is there any way to set it up so that I can control the volume using the remote? I don't think the volume comntrol on the Headline responds to the standard remote.
