Fitting a turntable shelf
Posted by: Steve G on 26 November 2001
More of a DIY than a Hi-Fi question this.
As I've been listening to my turntable a bit more recently I've noticed the occasional footfall problem causing the record to skip. To combat this I've invested in a turntable shelf - a Wallnut II (see http://www.britishaudio.co.uk/wallnut2.html ).
According to the instructions this needs mounted directly to studs in the wall. I'm no DIY expert (somewhat of an understatement that) and while I've located the wall-studs (it's an interior wall) they're way too far apart for the shelf to be fitted to two of them. Bearing in mind recent scare stories here about falling LP12's etc how should I go about fitting the shelf?
Steve
