250 with quad electrostatics
Posted by: john rubberneck on 03 December 2002
Anybody had any experience with this combination, specifically with regard to the amp cutting out at high-ish volume levels on one or more channels, it will reset after it’s been switched of for a few minutes, is this not a good combo?
Stuart
Posted on: 03 December 2002 by Manu
You have to call Naim with your speaker model. The 250 can output a too large voltage for some electrostatics. They can tell you if there is a mod to do on the amp to protect your speakers.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 04 December 2002 by David C
John,
I have driven Quad 988's with both a NAP 250 and a NAP 135, personally I don't think that the naim amps are the perfect partner for the Quads, and I sold my 135's and moved elsewhere. I still have a 250 that I occasionally use with the Quads. The voltage issue is not that important with the newer quads but the big problem is their imedence drops which can cause the 250 problems. Strangely I have a 250 with a 3 digit serial number that was serviced by Naim recently and that works far better than a green style 250 that I used to have.
Posted on: 04 December 2002 by J.N.
I have run my ESL 57's with a 250, many times.
No problems at all, apart from the possibility overdriving the Quads and damaging them.
Posted on: 04 December 2002 by john rubberneck
Sory model ELs63s
Stuart
Posted on: 04 December 2002 by Onthlam
John and or Stuart,
I drove my 63s for over 10 years with a 250.
No issues at all. You can if you like, have NANA set the voltage on the 250.
What also helps is to make sure you have the latest protection mods for the Quads.
Other than that,well...you can crossover at the input of the 250 at 40Hz. Get a pair of True Subs and go nuts with the fun you would have?
More on this if you are interested....
Marc
