Power Supply Advice
Posted by: ian1948uk on 09 September 2003
Hi All
I entered the Naim Domain over the last 2 years acquiring ex-dem and almost new kit along the way to give me a modest starting point. Currently I have a CD3.5, NAP90.3, NAC92, Intro2s and Naca5 cable.
I'm now thinking of buying separate power supplies on a limited budget.
The quick solution seems to be a Flatcap2 (possibly £350 used). I guess I connect one output to the cd but what do I use the other for?
The other option seems to be to buy a single Flatcap1 at about £250 (used) for the cd and then save the same again for a second Flatcap1.
I'd appreciate opinions/advice on what is considered to be the best route. However ther's little chance of me upgrading the cd player so the above seeme to be the arena that I'm in. My musical tastes are varied but centre around the likes of Van Morrison, Robert Plant, John Fahey, Eric Clapton, Rolling Stones, and some ambient/chill stuff (Claude Challe etc).
Thanks in advance for any help.
Best regards
Ian
Best regards
Ian
