Lead Direction
Posted by: garyi on 15 August 2001
Ok I have a 92/90 and a flat cap. Which direction should the connecting leads be the leads are NA 40 & NA 46 the names of the leads are at one end of the lead, if someone could tell me therefore where the 'named end' goes that would be great.
That is of course providing they are directional.
Posted on: 15 August 2001 by Arye_Gur
is from the label to the other end
Arye
Posted on: 15 August 2001 by garyi
Thanks for the direction but now which way do things need to be directed between the flat cap, preamp and power?
Naim dealer makes for me all the needed adjustments and this is one of the ggod things in Naim. You don't have to bother about anything.
So I guess someone from Naim should answer you for this question.
Arye
And a private sale hense no after sales service or naim dealers!
Also no instruction book either
Have to say I have used it quite happily for years, was just wondering is all.
Will check configuration just as soon as this record finishes!
Posted on: 15 August 2001 by Martin Payne
Is the manual for the old slimline series available on the Naim site. Some are?
cheers, Martin
Arye
where could I find these online tombs?
Ifb I'nm not wrong,due to problems of earthing,the signal goes from the pre to the power supply and then to the power amp.
So Lobo's scheme is correct and clear.
You can e-mail Naim with any question even if you didn't buy the equipment fron them.
You can find that they are helpfull and very polite and patient so don't fear to use them for any question- I'm sure you'll recieve a quick and deatailed answer.
Arye
Posted on: 15 August 2001 by Chris Dolan
Hi Garyi
Go to the Naim Homepage. Click on Products then Owners Manuals.....then take your pick on which you want to download.
If you don't have Acrobat Reader you can download that as well.
Hope this helps.
Chris
Posted on: 16 August 2001 by garyi
Does anyone know how to use the home page without that java crap on the left, I have a brand new system (Computer) and it can't load it, (My problem I know)
Its ok i found a 'Backdoor' in google.
