Customised Brass AV Wall Plates
Posted by: ErlangerBoys on 19 January 2007
Does anyone know where I can get some customised wall plates made up using a blank brass double wall plate? Requirements are for 2 HMDI sockets, a Radio and TV Coax and two 2 Cat5e all on one plate and a second plate that has Dolby 5.1 speaker configuration for 4mm banana connectors. Various sites have combinations but not the one's I require. I want to be able to supply the blank plates, as they are from a specific electrical range of wall plates not readily available.
Posted on: 19 January 2007 by David Dever
Stormcut
Posted on: 19 January 2007 by ErlangerBoys
Thanks for the information David.
Cheers Andy
Posted on: 20 January 2007 by Analogue
Try
www.photofab.co.uk
They specialise in chemical etching and engraving of all metals also the forming of electrical contacts etc..
Hope this helps
Posted on: 24 January 2007 by Paul Stephenson
In the UK there is a small engineering company called MP Engineering who can do this work. Contact Jezz on mp.eng@btconnect.com
If your face plates comply to the Euromodule standards then try
Stazie Hyslop
Technical Account Manager
In Touch Technologies (UK) Ltd
T: 0845 644 2401
F: 0845 644 2403
W: www.intouchtech.co.uk
W: www.konnect2.net
Posted on: 26 January 2007 by ErlangerBoys
Thanks very much Paul
