HELP Where's the BBC?
Posted by: Geoff P on 11 August 2005
Am I going crazy or has the BBC web site been unavailable for two days to anybody eles?
Since I can get here to post this I assume it is not a problem with my end.
regards
GEOFF
Posted on: 11 August 2005 by GML
Geoff,
I can view it OK, it hasn't been a problem as far as I'm aware.
Posted on: 11 August 2005 by Geoff P
Think it might be my dutch server is not recognizing ".co.uk" all of a sudden, can't seem to go to any sites like that only ".com" and so on.
Strange
Geoff
Posted on: 11 August 2005 by garyi
Have you tried a different browser?
Posted on: 11 August 2005 by Nime
Just "bbc" is enough in Google. You don't need anything else and it always comes top of the list.
Posted on: 11 August 2005 by Roy T
I expect that you are just a bit late paying this year's licence fee.
Yea good bloody point.
Stay off my website, I paid for that!
Oh I can do that alright but none of the LINKS work!
God are they charging in other countries aswell now....no wait a minute I do believe that is a Detector van..... yes he's stopping ...Oh dear he's coming up the drive....I'm not home
Yea good bloody point.Stay off my website, I paid for that!
...Look I was just working my way through listening to the Proms on Radio Three..That's all guv
Tried a different browser same problem. Must be they have fallen out with the EU
Posted on: 11 August 2005 by Guido Fawkes
Geoff P
What computer to do you have?
Try ping http://www.bbc.co.uk[/I] and www.bbc.com if they show the same IP address then something is wrong with your DNS settings. You may be pointing to a DNS server that is not resolving properly. I think www.bbc.co.uk should be 212.58.224.84 and www.bbc.com should be 212.58.224.123.
(If you have a PC rather than a Mac then you may need ping -a)
Alternatively, if you are using a proxy then that may be at fault.
If the DNS is ok then try clearing your cache.
Let me know how you get on.
Rotf
Geoff P
Apologies post should have read ..
Try ping http://www.bbc.co.uk and http://www.bbc.com if they show the same IP address then something is wrong with your DNS settings. You may be pointing to a DNS server that is not resolving properly. I think http://www.bbc.co.uk should be 212.58.224.84 and http://www.bbc.com should be 212.58.224.123.
Rotf
Geoff P
Sorry I don't know why the posting shows http:// in my ping statements - it must be something that gets put in automatically when I post. It should not be there
Posted on: 12 August 2005 by Geoff P
ROTF
Thanks for the help. I will check it when I get home.
I am getting there via a proxy server and by late last night I had a tried a few .co.uk sites and had the same problem. I use a cable modem via the local digital service which does TV & telephone aswell and I am trying to talk to them.
regards
GEOFF
ROTF
It was the DNS setting. Somehow my DNS had changed itself. The support guy at the cable co. gave me the DNS numbers and after I poked them into the settings everything was back.
Thanks for youre advice.
regards
GEOFF
Posted on: 12 August 2005 by Guido Fawkes
Geoff
You're very welcome. It is posible for a program or ActveX control to change settings on your computer. Glad the problem is solved and your able to get to the BBC again.
Rotf
