Is the flat cap 2 better on a cd player and pre or just a cd player?
Posted by: mystik on 30 January 2003
Is the flat cap 2 better on a cd player AND pre amp or just on a cd player?
IE: Would the effect be halved when split over 2 units?
I have a cd3.5 and a Nac72 pre.
Thanks guys
Posted on: 30 January 2003 by woodlowkev
For me the flatcap 2 made a big difference to my cd5, and when I split it with my 112 the upgrade was not so noticeable, but it defiantly made a slight improvement, although this is mainly at high volume.
I would like to try a black snaic to the 112 instead of the grey one that I have, to see if that would help.
Posted on: 30 January 2003 by Wolf
I have my FC2 powering both my 90 and CDP
sure makes a difference but try it in other configurations if you want.
Posted on: 30 January 2003 by Steve Toy
woodlowkev
Your findings are indeed the same as mine.
In blind listening tests I concluded three times out of three that the output A of the Flatcap 2 into the CD5 only, was better than output A into the 112 with output B into the CD5 as recommended by the manufacturers (iirc.)
A s/h Hi-cap into the CD5 would be better still, and then you could use the Output A of the FC2 to feed the 112.
Mystik,
In your case, you'd need to experiment using the two 'caps with the 72 and the CD3.5 respectively.
Steve.
Posted on: 01 February 2003 by mystik
I've ordered my brand new Flatcap 2. I can hardly wait. I sold my older flatcap and I'm hoping that whichever way I decide to configure it, it'll be an improvement!
Cheers guys.
