Troika Cleaning
Posted by: Chris Bell on 09 February 2002
Thanks in advance,
Chris Bell
ยต
By carefully stroking the stylus from the back towards the front with that GREEN STUFF supplied by Linn. I also 'lean' the green stuff slightly to each alternate side to clean the sides of the stylus.
By carefully stroking the stylus from the back towards the front with a piece of very fine emery paper or the striking stip off a matchbox, if you haven't got any of that green stuff supplied by Linn
By using the Audia Technica electronic stylus cleanning brush for AT LEAST 10 MINUTES without the liquid
Don
I'd like to drop it into a bath of something.
I own a slightly bent Arkiv with visible dirt.
(The question is, what to do with it? Is UKP700 a good deal? I bid UKP50 on a good looking K18 on EBay last week, it went for UKP72. This is silly money.... I have a worn out Goldring 1040 and I want to get back into 1000 lps. There should be an obvious solution for a Lingo/LP12/Ekos. It's actually looking like UKP700 at the moment....)
Paul
cheers
jim
enjoy
ken
jim
You might find this thread interesting.
BTW, I now have a Linn rebuilt Troika and still use the ES compound.
1) Use Linn Green Paper
2) Use a vibrating stylus cleaner
3) Use anything like Sty-last or other gunk
4) Use a demagnetiser
Do:
1) Using a squirrel/camel hair paint brush, get rid of excess fluff
2) Get some isopropyl alcohol and once every so often (in my case one a month) gently clean the tip
3) Get some putty or blu tack and clean th ewhole lot under a microscope
regards
Dev
enjoy
ken
What do you use to apply the alcohol?
Chris Bell
However, these observations are with Linn MCs only. I cannot vouch for others. I seem to remember that someone said that Dynavector does not recommend either green paper or vibrating brushes. Didn't someone report (was it Vuk?) that their stylus fell off a Dynavector while cleaning. Perhaps they are glued on unlike the Linn MCs.
Paul
Hope this helps
regards
Dev
Alex
PS Am I barred from future Saturday romps?
