radio on the n-Vi
Posted by: Robbert on 08 June 2006
I read that there is radio on the n-Vi.
Is that only DAB OR is it only FM OR is it both?
Posted on: 08 June 2006 by Richard AV
Hi Robbert,
You can have DAB *and* FM or no tuner at all. So, basically you choose whether you want a tuner or not and if you do, you get DAB and FM together.
Posted on: 08 June 2006 by Robbert
Thx, becouse i'm still thinking of trade my naim set for a n-Vi box.
What system do you have?
112x/150x/CD5x/FC2, and i love to listen to the radio.
Perhaps you do but how much do you value your CD playback? The N-Vi is a superb one stop shop for everything audio visual (the best on the market in fact) but compared to a dedicated system there are too many, um....compromises. Why not purchase a NAT05 or even a second hand NAT01?
Yes, but is the nat 05 also with DAB?
No it doesn't
Posted on: 10 June 2006 by Mr Underhill
Robbert,
Have you looked into the data rates at which DAB is transmitted in The Netherlands?
DAB in the UK is frequently very low.
It can be worth looking into other transmission routes, such as TV set top boxes - which can have higher rates.
Martin
