Has anybody tried AktiMate Speakers ?
Posted by: kev 1966 on 03 February 2009
Hi,
A) Has anybody tried and with what results ?
B) Can you use a Airport Express with the usb slot in the rear of these speakers?
Thanks in advance
Kevin
Posted on: 04 February 2009 by james n
a - no
b - The USB slot on the AE is printer only so not a lot else you can do with it (which is a bit of a pain)
James
Posted on: 04 February 2009 by kev 1966
James,
Sorry a bit of a misuderstanding usb on the rear of the speakers (As the Audioengine A5 speakers)
Kevin
Ah ok - isn't the USB socket just for charging other players etc that dont fit in the dock on top of the speaker (ie non ipod). It won't power an AE.
James
Thanks James,
Might have a look a the Audioengine A5s then
thats seems to work with the airport
Kevin
The A5 has a AC socket on the back so the AE plugs straight in as it would do into a normal mains socket - quite a neat idea for a compact streaming solution.
James
Cheers James,
Thats exactly what i'm trying to achieve, I see they picked up a what hifi 5 star award..
Might give them ago, seem good value for money
Kevin
