CD5 stopped responding to remote
Posted by: woody on 27 May 2003
My week-old CD5 has just stopped responding to remote - playback fine and front panel buttons work no problem. I've seen a post on this before - what was the solution (I switched it off and on again after a few seconds which seemed to fix it but is this the solution)?
Thanks,
Andrew
Thanks,
Andrew
Posted on: 27 May 2003 by woody
Thanks,
Andrew
Just played a disk, removed it, put in another and same thing...is it knackered? (it's not a huge deal as I can use the buttons but a bit - well, annoying!)
(oh yeah, and the remote works fine with the NAIT)
[This message was edited by woody on WEDNESDAY 28 May 2003 at 00:05.]
Posted on: 27 May 2003 by syd
Try turning it off for 5 to 10 minutes and see if this sorts it. I recall reading a thread about the microprocessor needing this time to reset itself. Hope this helps.
Yours in Music
Syd
Yours in Music
Syd
will do...i'll leave it off for 10 mins and retry. I'll post results here but i've powered it off for a couple of minutes and nothing...I can't imagine why 5-10 minutes with no power is different for a processor than 2 minutes but I'm willing to try. Otherwise I'll have to contact the dealer
just had a thought actually - CD5 is powered from FC2...do I have to turn this off as well? And presumably the NAIT which is also powered by FC2? So basically switch whole lot off? If so :
a. what's correct sequence for doing this?
b. how long do I have to wait for it to be back to normal as system has just started sounding sweet
- Andrew
- Andrew
Originally posted by Joolz:
might i suggest changing the remote's batteries. things can get very strange when they run down.
cheers
julian
I have 2 remotes - one that came with the nait and one that came with the CD5...I've tried them both with the batteries that came in the packages for each. No joy - even switched CD player off and disconnected FC2 input. Still no joy
Posted on: 27 May 2003 by Bob Shedlock
RE: microprocessor reset - it isn't enough to power the cdp down, it has to be disconnected from the ac line too.
Posted on: 27 May 2003 by Ancipital
I've done this one - wondered why the remote stopped working, pressed CD Input and voila, worked for me.
Steve.
Posted on: 28 May 2003 by woody
Done all this although when I disconnected the FC2 I didn't unplug from the mains, just switched it off on the rear switch. Will this make a difference? I'll retry with new batteries.
Posted on: 29 May 2003 by Maxi Me
Any joy yet Woody?
Is the new system coming on song?
Mine is sounding fab, I almost don't want to go out tonight with friends!
Seth
Is Naim the only way forward?
Ahh, Ahh! I'm burning!!
Seth
Posted on: 31 May 2003 by woody
Originally posted by Maxi Me:
Any joy yet Woody?
Seth
_Is Naim the only way forward?
Ahh, Ahh! I'm burning!!_
System sounding FABBO - got to crank the volume a bit yesterday and just sat there with a huge grin...just this bleedin' remote thing to sort out (still haven't got round to trying new batteries)...It's weird, NAIT working fine. CD5 = nothing. Powered everything off yesterday as I'd seen in another post and upon powering it all up again it worked - but nothing again this AM. Could it be the batteries? hmm...I'll post here.
Posted on: 01 June 2003 by woody
hmm...appears to be power-on sequence.
I think before I was doing FC2->Nait->CD5.
Just put brand spanking new batteries in. Left of for 10 minutes.
Powered on, according to another thread:
CD5->FC2->Nait. Remote is now working. It has worked before and stopped overnight so I'll post an update so, in case anyone else has this problem, they'll know what to do. For now,
(although I'll see in a few days).
Sorry if I'm being boring!
- Andrew
- Andrew
Posted on: 02 June 2003 by woody
The unit is going back to Naim - apparently it may be a "chip issue". So I'm getting a replacement on Thursday. Thanks Pat@Billy Vee for sorting that one out.
Posted on: 02 June 2003 by Maxi Me
Good luck Woody, hopefully this will be the end of the problems and the beginning of Audio Nirvana
Seth
Seth
