Older manuals
Posted by: Stephen Bennett on 16 November 2001
Are there manuals for older equipment anywhere? I'd like them for my CD 3.5, FlatCap, 72, 140 & Hicap!
Stephen
Posted on: 16 November 2001 by Paul Stephenson
We have manuals, just mail the factory with your details.
Posted on: 16 November 2001 by Ade Archer
Is there a proper manual for recent SBL's. I purchased mine 2nd hand, and although the setup sheet that comes with the re-sealing kit was inside, I was wondering if there should be a seperate manual similar to the one that comes with the other equipment.
Ade
Posted on: 17 November 2001 by Martin Payne
Originally posted by I remember Vuk Vuksanovic:
Stephen,The hicap one should be on the site.
Beware that the wiring is different on the older HiCaps. There should be a warning in the manual re only appropriate for PSs after a certain s/no. I feel it's a significant ommission that it's not there.
Posted on: 17 November 2001 by Ade Archer
Ta Dave,
I'll contact Naim. Anyone any ideas how much a manual is?
Ade
Posted on: 19 November 2001 by Paul Stephenson
"was only just over a tenner" its a mistake send it back should have been £100, joking!!
manual would be sent foc.
Posted on: 05 December 2001 by Paul Stephenson
I think you will find we normally send manuals out free of charge.
"my PXO test/repair...."
Could be tricky ![]()
Posted on: 05 December 2001 by Scott Mckenzie
Do you have any other old stuff you can send out foc - i'm after a CD3.5, Flatcap, Credos and a 140.....
Scott
I wish you had said, they have all gone!
Are you serious if so mail the factory!
Posted on: 08 December 2001 by Paul Stephenson
Sorry, don't think so, email me your address and I will get you a manual.
Posted on: 09 December 2001 by Scott Mckenzie
erm...ok!
What are my chances? I'm not too worried about the Credos at the moment...other stuff would be nice though...
Scott
