Any used hifi eqt websites based in UK?
Posted by: silklee on 24 June 2002
Esp those with a high incidence of naim eqt...
Posted on: 24 June 2002 by David Quigley
I think that the following two are the most populat
www.loot.co.uk (case sensitive i.e., Naim)
www.topica.com (check out naim market)
Regards, David
Regards, David
Posted on: 24 June 2002 by silklee
http://www.loot.co.uk (case sensitive i.e., Naim)
http://www.topica.com (check out naim market)
Regards, David
Thanks.
Posted on: 24 June 2002 by Clive Gidney
I have located some searching google.com for "second hand" Naim which produced quite a number of number of options worth a look
Clive
Clive
Posted on: 24 June 2002 by Stephen H
Try ex-dem.co.uk
This searches lots of 2nd hand sites and lists them in descending update date sequence. It is an easy way of coming up with a list of sites to visit, but it can be a bit infuriating when the bargain you spot near the bottom of page 2 is from a web-site last updated in 1997 though!
Steve.
Steve.
