Cheap MC cartridge options
Posted by: Jellyheadjeff on 23 September 2001
I've mentioned this as part of another thread but had few takers. I have just bought a s/h NAC52 with NA523s. However I currently have a MM (LP12/Valhalla/Ittok/K9. Therefore I either need to buy a MM phono stage (NA522 or Stageline or others - please suggest) or switch to a MC cartridge. Sadly my use of the LP12 has diminished to very occasional at best so I am keen to keep any outlay to a minimum.
Are there any viable budget MC cartridge options I should consider (as a 522 would cost me around £80+ I would limit consideration of other options at a max of £200. I was interested to see that from a previous thread you can purchase a OC9 for $199 - never heard it but sounds cheap for an item that used to sell for alot more 10 odd years ago - is it still the same product? Are there any £100-150 MC cartridges these days (I'm thinking of the OC5/OC7 days)?
Jeff
