Wasn't there a "Whats your backup?" thread?
Posted by: Tarquin Maynard - Portly on 24 July 2009
If so, what happened to it?
M
M
Posted on: 24 July 2009 by seagull
It wasn't backed up...
Posted on: 24 July 2009 by JonR
Ho-de-ho!
Posted on: 24 July 2009 by 555
Posted on: 24 July 2009 by shoot6x7
It was my thread ... it's still there on the HiFi Corner forum ...
Posted on: 24 July 2009 by Tarquin Maynard - Portly
Thank you - I did a search for "backup" and "back up" to no avail.
So nothing wrong with my memory, despite the hilarious cartoon above.
Posted on: 24 July 2009 by bon
555: I'm sure you've used that cartoon ...... Oh! Sh*t was was I going to say
Posted on: 25 July 2009 by 555
No Mike, you have issues with your memory, sense of humour & the forum search tool too!
Posted on: 25 July 2009 by Tarquin Maynard - Portly
There was / is a "backup" thread, so nothing wrong with my memory.
I've said I used the Search function, which did not produce a result.
The cartoon remains hilarious. Really.
Posted on: 25 July 2009 by u5227470736789439
I have found the search engine is not perfect [or so experience has shown] until the topic is closed.
Perhaps it is only a rough correlation as perhaps it has more to do with the periodic backing up, and that a null-result is because the thing is not somehow completely cogged into the permanent[ish!] record!
I don't know, because on other times it works well soon after a post has been made.
ATB from George
ATB from George
Posted on: 26 July 2009 by Tarquin Maynard - Portly
Most Illuminating.
I think our views of "humour" really do differ...
Posted on: 26 July 2009 by 555
Please feel free to have the last word. I will not bother with you again.
Posted on: 26 July 2009 by Mick P
555
Sending in posts which contain just a pic or just a smiley is about as low down the pecking order you can get when it comes to contributing to a forum discussion.
Mick
Mick
No doubt Mick makes a living from his witty & perceptive opinions.
quote:A picture is worth a thousand words
