Wall Mounting Speakers...
Posted by: Scott Mckenzie on 29 November 2001
The main question is, at what height should the speakers be mounted, as I understand poeple will say "tweeter at ear level" however my kit is in my bedroom, and I listen to it when I am working at my PC and when just listening....therefore my ears are at different levels...
The dyn wall mounts are adjustable both horizontally and vertically..so I was thinking about mounting them a little higher on the walls and pointing them downwards so as to be the best compromise...i think this would work as they will be mounted above my head when working, but for plain old listening I will sit further back and consequently if i get the angle right they should sound fine...
My main question then is: Is this a good idea, or would a different method be good? FWIW I cannot go around randomly drilling holes in the wall so I could do with getting it right first time around...
Any help greatly appreciated.
Scott
