How to improve the bass from a CDI ?
Posted by: Arye_Gur on 26 November 2001
Lp12/ittok/asaka/armageddon, CDI, nat03, 102/napsc/Hi , 140, IBLs.
The CDI lies on the top of a QS, the TT lies on a cheap metal/mdf stand.
The bass from the TT is much better than this from the CDI and the sound from the TT goes lower than the sound from the CDI.
Is there any idea how to improve the bass from the CDI ?
Arye
Are systems are quite similar at the moment, except that I use a CDX. I'm afraid that I don't believe that there is any easy way to get better bass from your CDI.
A better Cd player would do it, but I don't know of any quick fix for your situation. Of course my usual advice would be to put the player on a decent stand, but you have done that very nicely. Possibly putting the rest of the equipment on QS could help.
Best wishes,
Bob.
PS just noticed that the CDP sits "on top" of a QS, so I guess that the amps are under this.... rules out my QS idea then ![]()
Does the CDX give you the same bass as the TT ?
Arye
Put it on a Fraim! ask Ilan to do you the demo
That could give you some perspective on what's happening.
Also, have you tried your CDI on the bottom shelf? A stupid location but I've noticed CDPs sound better the lower on the rack you go.
I get a feeling that these'll help but by no means will it turn water into wine...
I used to use a CDI next to my LP12. The CDI & CDX are both a bit bass shy compared to the LP12. I guess you can't use the player on the bottom shelf because of the top loading. I intend to get an XPS one day & that should get thing a bit more even, for me.
I'm sure Paul S's 'helpful' tip might help, but this will cost. Is your problem more with the quantity of the bass or the quality? I think the quality of bass from the CDI is fairly good. Don't let someone try & persuade you that the IBL's are too bass light. Their bass is fantastic when given the correct information.
Best wishes,
Bob.
PS: you do use NACA5 I hope
However this* was an expensive upgrade so maybe a Fraim will be a better option for you!
regards
Geoff
I know you've been advised not to change your speakers but my personal experience has been that the thunderous, gut-wretching bass I'm now enjoying just wasn't there when I used Kans or SBLs (I've never heard the IBLs). If anything, the CDI goes deeper than the LP12 in my current system and room. Bass or not, the CDI is an incredible player for the money. I was very strongly advised by several dealers not to change to a CDX unless I was flush, but to spend money elsewhere in my system (pre-amp in my case).
Steve
I think that the CDI can give more, and I'm going to get for a test a brightstaraudio shelf that comes on the present stand .
Paul Stephenson,
I'm going in a few days with the CDI to Ilan to listen to it on a Fraim with intro2, but this days I can't afford the Fraim.
Arye
I have a chord anthem on it, but to be honest its not a major upgrade from the basic naim lead.
Disconnect LP12 from mains & amp. Also disconnect any other items except the CDI.
Move LP12 into another room.
Now try the CDI again. Any difference?
cheers, Martin
Several days ago I tightened it and that
solved the problem with the CDI bass.
I was told that a "tightened" QS makes the music too "hard", I don't find it is true.
Arye
