linn speakers
Posted by: Action on 20 February 2002
Can someone fill in my blanks!!!
I am leaning towards s/h linn speakers(£700ish).
But I'm confused ;
1. sara/isobarik
2. isobarik
3. isobarik/dms
Any info on suitability for my 72/180 etc would be gratefully accepted
Thank you ....
A set of Saras will set you back £300ish.(If you decide to go down this route, Ihave a pair for sale in black) Isobariks will cost more, but if you have the space and listen at realistic levels then I feel it is worth it. You will need the DMS which is passive ie only needs a single amp, whereas the PMS requires an electronic crossover and 3 poweramps. Expect to pay £400-£700 depending on age/condition. Remember these speakers were in production for over 15 years.
mentioned speakers ?
do yours have the xlr connections,if so what the hell are they ,and will i be better getting my dealer to make up the cables
Do you have a *-cap with your 72/180? The end result could be rather flat with 72/180 into Sara's or Bariks. These speakers need juice. Might not be too bad since your room is on the small side - and depends how loud you want to play.
- GregB
Insert Witty Signature Line Here
Flat/square fronted cabinet edge, horizontal XLR
Round cabinet edge, horizontal XLR
Round cabinet edge, vertical XLR
SARA 9, round cabinet edge, 4mm bananas.
The latter has a normal dustcover on centre of the outer bass driver, the earlier ones (I don't now for how long) had a large disc of soggy cardbaord stuck onto the cone.
FWIW any SARA will be at least 12 years old. And will be comprehensively blown away by a pair of Kabers. Kabers are also more flexible at room integration.
But you should also get to a dealer and listen to the new stuff in your price range. Nostalgia aside and with the rose tinted spectacles aside a pair of Ninkas will probably outperform any of the 'old' favourites, unless we're at the seriously active Isobarik level.
Paul
I suppose different peopla are just looking for different things.
One last point, There were two versions of the 4mm plugged Saras.Single wire and Bi-wire with removeable links as per Kabers.
I actually upgraded from Kabers to Saras and (looks aside) never looked back.
I went the other way....
I still have the SARAs, they're a pretty old horizontal XLR version, but more appositely last year I impulse bought a late pair of KAN 1, with the 4mm sockets. And I've tried these in my present room. And there's still no comparison.
My Kabers have the so-called 'scratchy' ceramic tweeter, I shall probably try the newish whatever it's called version. I can twiddle the activ cards to rebalance if necessary.
Paul
Now where is that june 88 copy of hifi review???................
Mike
