A few hours with a Unitiserve, Snait, nDAC and my PC
Posted by: Occean on 28 September 2010
Currently I have a Supernait which is fed by my PC (Win 7 64bit/3.0ghz/ssd/nas/foobar/ESI Juli@) into my Spendor S5e’s + REL Stampede. I know the obvious upgrade for this is a Hicap2, but as it happens I currently have £2k ish I can spend. I really like the idea of the Unitiserve – yes my PC works just fine but a separate solution seems like a good idea to me. Also with all the hype of the nDAC and it being £2k, I thought I had better have a listen too….
So I organised a demo at O&L in Clapham, called silenttim from the forums to join me.
Unitiserve + Snait
Unitiserve + DAC + Snait
My PC + SNait
My PC + DAC + Snait
Speakers were PMC GB1 which I have heard many times before.
So I brought a couple CD’s (Martina Topley Bird, Antonio, Audio Bullies, Waldeck) ripped them with the Unitiserve, nice – must say that’s easy! So first up was the ‘serve, snait and with a DC1. Oh my it sounded so different to my home setup, the top end was really edgy in a negative way, I guess I was not as familiar with the PMC’s as I thought. Listened to a few tracks, all had the edgy topend, overall I wasn’t happy – I check with the guys that everything was warm and run in, they confirmed.
So we dropped in the DAC – everything started to sound lovely. The top end was smooth again, more detail and all the good things you expect but it wasn’t a million miles from my home setup. Not sure about the PMC’s at all. Repeated all the tracks
Next step was to setup my PC, optically into the Snait with the Serve connected via a DC1. The difference was astounding, we could both hear quite a big difference…my PC was better! The ‘serve had the same edgy sound to it as before, but my PC had all the detail and resolution (and reading FLAC’s) but the topend sounded so much better to both of us, even a quick blind test, everytime we could tell the difference. I was shocked and I must say a little disappointed, I loved the idea of the serve. But my confidence was restored in the PMC’s.
So finally – PC to DAC to Snait as well as the ‘serve – the DAC made a nice improvement to the PC, soundstage was widen and everything was just a little sharper but I was not convinced at £2k better…I know a Hicap’s improvement is a lot more than this.
So what did I decide, well I am booking the DAC for a home demo. The serve, well if it sounded as good as my pc (I was expecting that at the least) I would have ordered there and then, it didn’t – this has made me realise that my PC does a damn good job, it has always outperformed my Mac and sonos. So I may build the *perfect* PC instead.
As for the DAC, it was good, but not £2k better than the Snait bare, I need to thing long and hard about my upgrade path, if I decide to go 282/250 the DAC is a must, but I am not sure I want to go that far and unbalance my AV system so much (it sounds friggin awesome right now).
Posted on: 28 September 2010 by james n
Good write up with some interesting results.
James
Posted on: 28 September 2010 by js
Not what I'd expect and yes, tos being better and them so different is most interesting. I haven't heard the serve yet but the HDX that it's based on has no edginess for me whatsoever. You have to go with what you heard but it seems something in the package or setup may have been bright other than/besides the serve. Tos usually softens things a bit and here it was helping along. Pure speculation on my part.
Let us know how it goes if you do a home dem. Are you using WASAPI?
Maybe an NDX will be right up your alley. I suspect it's character may be more pleasing to many.
Posted on: 28 September 2010 by Occean
I wish I had brought my breakout cable for the coax from the Juli@ (PC) for a direct comparasion. But home sessions have revealed nothing between the optical and coax outs into the supernait.
Yes I was using WASAPI and the NDX is not for me, there are so many things I do not like about it.
Posted on: 28 September 2010 by Jan-Erik Nordoen
Could you elaborate on your Mac setup?
Interesting post, and at odds with my experience of the Serve.
Jan
I must admit my Mac setup was limited, itunes/alac/macbook/hiface to supernait.
It performed as well as my sonos but the PC setup was always just adhead, whether it was the itunes rip or something else I never knew. I also feel the Mac setup has too many disadvantgaes to the PC for audio playback.
I am not saying the serve is bad, but my ears are used to a different sound.
Don't worry, you won't offend any card-carrying members of the Serve Mutual Admiration Society
Our motto :
To Serve and Protect
Posted on: 29 September 2010 by AbsoluteMusic
Dear Ocean
Could you please be a bit more precise.. what dont you like on the NDX
Posted on: 29 September 2010 by Occean
Dear Ocean
Its just a personal thing, I am sure it sounds great and will be perfect for some people.
Hardwesr
A £3000 unit that seems to be part nDac £2000 but not the same quality and 50% Uniqute £1300 for me it doesn't add up.
Software
I much prefer the HDX/Serve software, which is a server rather than client. Again for £3k I don't want to reply on 3rd party upnp server software. I'd like to have seen the serve software minus ripping (a la Sonos and DS). No 176/192khz support in upnp.
If I had to sped £3k a sneaky DS and Ndac or I'd save another £1k for a serve.
Dear Ocean
Hardwesr
Software
oki..tks for the clarification. I'm also not fully convince by the "net" solution. (would prefer a dedicated "all in one" solution) Basically like which proposed by the HDX...but not at it's current price....to much by a lot if looking on the component used....Must admit that coming from the IT world i cannot imaging today spending this sum for an HDX
.. tech looks a bit un-mature )
Just my two cents
Posted on: 29 September 2010 by js
I just had a fun session with a MAC, PC and the HDX. The INT202 was used as interface for the laptops so not cheap either, all into Naim DAC/555ps/552/500/auditor M/REL B2. HDX via SP/dif was still tops followed by Wavelab/ASIO/PC, then MAC/Amarra and everything else was a bit further off. Wavelab isn't a library player so it won't be acceptable to most but it was absolutely the best program player. Amarra was clearly better than the rest IMO, including the free Windows players via ASIO/Kernal and MAC/Pure Music. Itunes was again a notch down. The winamp/media monkey/foobar were all about as good as PM but they were also noticably different except for WA and MM. Not wanting to get too involved of fine lining the next tier after finding Amarra was the best library player. Buffer was at 10 on WA/MM for this go around. All IMO and your results may vary. I will not get into %s etc. but thought I'd give a quick recap as I had everything side by side with HiRes wav files. Where a serve fits in, I can't say as I haven't auditioned yet.
Posted on: 29 September 2010 by Joe Bibb
I have Amarra and Pure Music running on a Mac, and now the "Play" which is free. All three sound better than iTunes to me, but PM 1.63 in HOG mode is the one I prefer, that is really good. To be honest Amarra and Play sound pretty similar to me, maybe Amarra just ahead so worth having a look at Play if you have a Mac with no music software other than iTunes.
I have not heard any Spdif that tops Firewire, whether CDT or computer. I wouldn't drop 4 grand on an HDX - it has too much I don't need and when I've heard it feeding a DAC it was no better than Linux PC or Mac. So as JS says YMMV etc.
Joe
PM was in hog but every setup is different. Value vs better is also a very individual equation.
Allen, HDX was updated to latest but not SSD or BNC connector, both DAC and HDX earthed and only DAC connected to 552 for all auditions. HDX played via NAS and the other 2 played via the same files transferred to their internal drives so it could be part of their libraries without much manipulation. If anything, the HDX was at a disadvantage depending on your take of distant multi use nas vs local.
Posted on: 29 September 2010 by realhifi
"As for the DAC, it was good, but not £2k better than the Snait bare, I need to thing long and hard about my upgrade path, if I decide to go 282/250 the DAC is a must, but I am not sure I want to go that far and unbalance my AV system so much (it sounds friggin awesome right now)."
"Friggin awesome" sounds like a pretty damn good place to be with your system I would have to say! The thing is, at this part of the journey the rewards for spending more start to feel like a slippery slope. Expenditures at this level start to get more subtle and not always black and white. What gets interesting is whether the change or addition of something actually IMPROVES the playback of music. Not always the change that is most obvious DIFFERENCE but the one that actually digs deeper into the heart of the music.
Remember what the most important thing is about your system; that is simply getting what the artist recorded, (the recording itself) as unscathed as you can into your playback system. Once that is accomplished you can worry about amplifying it. Now is when things get interesting for you.
What else is there?
Posted on: 30 September 2010 by Nagoya
Apologies for interrupting this informative thread, but Occean can you please drop a few words on what components you would use to build your perfect PC. I understand that this is going to be tailored to your own audio system, but I am also thinking about building a PC, and as I don`t have much experience in this area I'm looking for a few pointers.
I have been looking on the computer audiophile site, and while there`s a lot of useful info there, I`m a little overwhelmed. Also, they seem to focus on dedicated HTPC builds, whereas I want to build a computer for general use as well as high quality audio and HD video. Perhaps, for an easier life, I should go for one of the latest Imacs but I thought I`d explore the PC route first. Thanks very much!
Posted on: 30 September 2010 by Occean
Well I am speccing it as we speak...
ASUS AT5IONT Motherboard (dual 1.8gig atom/ION)
4GB DDR3
RME HDSPe AIO (PCI - express)
OCZ SSD
1tb 2.5 WD (if I decide to hold music locally)
King Rex linear PSU (from item audio)
Slot loading Bluray
Win 7 64bit
Approx £1.1k
I believe the linear PSU and the Soundcard are the two key things to the ultimate rig. The PSU is only 90w so I had to choose atom cpu, and the best atom motherboards are only PCI express hence the choice of card (which seemed perfect anyways).
Video wise the ION2 motherboard will happily play HD and Bluray and the soundcard will output DTS and DD (Some pro cards don't - I need one feed to my snait and one to my AV2 - this card can do it.)
Case to be decided....I have lots of idea for this. But will be totally passive.
Posted on: 30 September 2010 by js
Looks like a nice rig. I wish you could find a card you liked that didn't require a breakout cable for coax. The only one I'm aware of that's not just a cheap card is the M-Audio 192 and I haven't been a fan of M-audio drivers in the past. Probably sorted by now. It's also ancient by todays standards.
The RME looks good and is output transformered. I bet it wouldn't be difficult to do a panel or flying lead mod if you ever felt the need.
Posted on: 30 September 2010 by pcstockton
Ive been eyeing this set-up from CA.
The Computer Audiophile Pocket Server piece by piece
Motherboard
# Intel D945GSEJT Johnstown Mini-ITX Motherboard - $109.00
Power Supply
# Power Adapter DC 12 V, 80 W - $29.00
RAM
# TRANSCEND 256MSQ64V6U SO-DIMM DDR2 667 Memory 2GB - $73.00
Solid State Drive
# OCZ Vertex Turbo OCZSSD2-1VTXT60G 2.5" 60GB SSD - $219.00
PCI Riser
# PCI Riser Card for D945GSEJT - $10.95
Digital Audio Card
# Lynx AES16 PCI Audio Card - $625
Custom AES Cable
# Lynx AES16 Cable - ~$60
Computer Case
# Origenae M10 - $320
Music Application
# J River Media Center 14 - $50
Posted on: 30 September 2010 by realhifi
JS....there are many instances when someone has told me of a huge leap in performance brought on by this or that only to find out the "improvement" turns out to be a false
sense of extra detail or huge change in dynamic ability that ultimately fails to satisfy.
The context of my response to Occean is simply to point out the need to first look at source because of the real improvements in music communication that come from the "source first" religion. Whereas simply making something more dramatic or clearer or bassier or whatever often times is perceived as better when in fact a simple change which is not so obvious further up the chain can bring more real and lasting benefits.
That was too long wasn't it!?
Posted on: 30 September 2010 by Hook
Hi Patrick -
That's what I've been using for several months. I substituted the RME 9632 for the Lynx AES16 (on Eloise's recommendation), and have been very happy with the results.
Hook
Redco Audio does a nice job of building custom cables. I bought a DB9-to-BNC S/PDIF cable from them to connect the RME 9632 to the Naim DAC, and it has worked well for me.
Hook
Posted on: 01 October 2010 by Occean
Personally I think the CAPS build on the CA site gives away a little too much for ability to be portable and it also a little out of date now in terms of hardwear.
A single core atom was chosen as the duals were not passive at the time, now the next gen atom chips are in an the duals are even faster, more ram, less power consuming and passive.
The psu is a smps unit, a liner unit should be superior. Though not portable.
The case is cramped and the pci card is not actually mounted so the outputs are available on the outside, rather cables need to be routed though gaps. Something like atechs passive case would be much more suitable as a home unit
Posted on: 01 October 2010 by Jan-Erik Nordoen
...oooh, I want one, or one like this:
thought you might like that
there are also the Mcubed cases which are a lot easier to get hold of in the UK - they also do a mini one that takes a PCI card
Posted on: 01 October 2010 by Hook
The HeatSync 2500 is a beautiful case -- looks great. But $569....with no options selected?
I love the DIY approach when it delivers excellent sound and maximum functionality...at a reasonable cost.
IMHO, if you start out with such an upscale case, then you may run the risk of pushing your total build cost pretty close to manufacturer-delivered turn-key solutions.
And I thought I was over-the-top spending $200+ for the Origen case last February!
Hook
