Phono Board for Denon DL110 (high output)
Posted by: MJSM on 15 November 2003
I have just purchased a high output MC cartidge for my LP12/Ittok set-up and would like to know more about which board to fit inside my NAC72.
I'm told that the output
Output Voltage 1.6mV (1kHz, 50mm/sec)
is high enough to go through a MM board, but am not sure if this is the case.
Furthermore, is it only down to the minimum voltage, or is there more to the story than this. I have just bought some 323/k boards off Ebay thinking that I would need them (silly really, should have asked this question before I bought them), but I'm told that it's better to use the MM boards as the noise level is lower.
Help ......
Lastly, I'm not interested in a prefix or whatever, so that's not really an option, just need to know which board - MM or MC (and if MC, do I need the 323/K or the 323/S)
Mike
All advice gratefully received
Smile
Posted on: 16 November 2003 by quickie
Hi Mike,
You will need to use 322 MM boards.
Bear in mind that the output of the denon is quite low for a high output moving coil(most are around 2.5mv,so you will have to turn the wick up a bit more.
Paul.
Posted on: 16 November 2003 by MJSM
Paul,
I have already got 323/K boards which I intended to use, is this a better option than 322 board ?? or are they inherently noisy ??
Mike
I think you will get too much gain with the MC boards.
Most low ouput moving coils are around 0.25-0.6 mv output,this is what the 323's are intended to be used with.
The Denon is 1.6mv so it will sound very loud,probably hissy as well,but you can try it.
Paul.
[This message was edited by quickie on SUNDAY 16 November 2003 at 16:48.]
Posted on: 16 November 2003 by Markus S
Ask Naim if the 110 will overload the K boards (it probably will). If not, you can use them.
