Vivaldi "Four Seasons"
Posted by: Rubio on 19 November 2005
Does anybody have a recommendation for a CD (not SACD/DVD Audio) with top-notch performance/sound quality of Vivaldi "Four Seasons" (not too original I know, but the person who receive it will like it)? It should be a gift to someone who doesn't have too much experience with classical music, so I would like to have recommendation for an orchestra that does the performance in a way that is "consevative"/"romantic" rather than experimental/pushing the boundaries.
Posted on: 19 November 2005 by Tam
Take a look at this thread:
http://forums.naim-audio.com/eve/forums/a/tpc/f/380...2940996/r/8792940996
regards, Tam
Posted on: 19 November 2005 by Huwge
For something a little different I can heartily recommend Gidon Kremer's version which combines Vivaldi and Piazzolla in a disc called Eight Seasons
Huw
Posted on: 19 November 2005 by Rubio
Thank you very much for the input. I think I will go for the SONOTORI DE LA GIOIOSA MARCA, GIULIANO CARMIGNOLA, VIOLIN on Hybrid SACD as proposed by Cosmoliu in the thread mentioned above.
Posted on: 19 November 2005 by Cosmoliu
Rubio,
Yes, definitely. You will not regret it. Smile
Norman
