A quick speaker cable related question (but NOT one about which to buy!)
Posted by: CraigP on 05 February 2003
New to Naim so please excuse a possible silly question, but from reading the archives there seams to be a lot you can do to maximise your sistem without spending anymore money:
I have a Naim Nait 3 which is sat on a Quadraspire table with a CD5 on the shelf above. I purchased 2 x 4m of NACA5 which is far more than was required, but i wanted to exceed the 3.5m min length, so the rest of the speaker cable is wound in S bends and NOT carefully shoved under the bottom shelf on the floor in a general mess. Is the insulation on the NACA5 sufficient that there would be no interference from the 2 channels of wire being all criss-crossed together, or should i attempt to seperate the cable into 2 distinct lots?? (it may make no difference but for a small job if it made an improvement then great).
Also i have ordered a new Headline and NAPSC, can these sit on my shelf on top of the Nait 3, or would this also cause interference of some kind??
Thanks in advance
Craig
Thanks in advance
Craig
