B&W 805 Signature and Bi-Wiring
Posted by: rorominator on 30 November 2003
Hi everybody,
I use not to biwire my 805S.
First question : would it better to bi-wire them with Naim electronics ?
Second question : If I "just" single-wire them, which jumpers should I use ? Those provided with the speakers (short length cable B&W brand) ? short length of NACA5 ? Any other idea ?
Thanks for your replies.
Roro
CDX/202-HiCap/135
Posted on: 30 November 2003 by Tuan
Originally posted by rorominator:
Hi everybody,
Roro
CDX/202-HiCap/135
Use the Naim cable to replace the jumpers and keep the single wriring configuration. Your 135s are more than enough to drive those speakers.
Posted on: 01 December 2003 by Emil F
Roro
Use single NACA5 with F-connection for the binding posts of the B&W. There is no better solution.
Emil
Posted on: 01 December 2003 by rorominator
thanks a lot Smile
so I'll keep single-wiring with F-connection.
Regards.
Roro
Posted on: 01 December 2003 by sean
Roro,
While bi-wiring bay not be the way to go with these speakers, bi-amping certainly is. I had a pair for a little while with 4x135s, fantastic grip and drive if you can afford it.
Sean.
