Cheap cartridge help needed
Posted by: i am simon 2 on 21 July 2003
My goldring 1022 has past it, I think a combination of age and over zelous use of fluid type cleaners on both records and stylus have gooped up the stylus assembly, the stylus itself and who knows, maybe the internals as well.
I realy dont have enough money to replace/upgrade it at the moment, but I want to listen to records.
The obvous short term stop gap is a Rega Bias or Super Bias.
I have a Planar 3 with original R200 arm (s-shaped).
Does the Bias fit the headshell on this arm?
Is it worth thinking about either of these cartridges or should I just stop listing to vinyl for the rest of this year?
As it is only a stop gap, is the Super Bias worth the extr few quid over the normal Bias?
All help would be appreciated.
Simon
p.s. I will keep the Goldring stylus and body for an exchange at some point, maybe a 1042, when I can afford it.
Simon
