Anyone having a problem with Spotify tonight?
Posted by: Blueknowz on 18 January 2010
The Anti Virus AVG is showing it up as a virus on my Vista laptop!
Posted on: 18 January 2010 by Blueknowz
Sorted, If you are an AGV user do:
1. start AVG user interface (right click on AVG in system tray)
2. select components -> resident shield
3. select click manage exceptions
4. select Excluded files, click Add
5. browse over to c:\Program Files\Spotify\spotify.exe and select the file then click open
6 spotify.exe appears in the list with a selected tickbox - click apply
Posted on: 19 January 2010 by BigH47
What's virus software?
Posted on: 19 January 2010 by ewemon
Ha! Ha! best laugh I have had in ages.
Posted on: 20 January 2010 by Bob McC
all you need do is update the definitions via the update now button.
Posted on: 20 January 2010 by Blueknowz
Bob ,It took AGV 2Days to release a patched update!
