mains spur
Posted by: longmanjon on 24 February 2008
i want to install a separate mains spur for the system, but am confused as to what i have read.
i have got a new consumer unit just in case, but do i just run a length of twin and earth to the current fuse box or install this separate unit instead??
jon
Posted on: 24 February 2008 by 151
if you have already got a new consumer unit it would be better to install it.
Posted on: 24 February 2008 by FangfossFlyer
Suggest you get an electrician to do the final connection to the CU and incoming supply.
Posted on: 24 February 2008 by Happy Listener
Longmanjohn,
Forgive the statements of perhaps the obvious, but this is a job for a trained electrician.
You can either run a new spur from the existing consumer unit, assuming you have a spare circuit/breaker in your CU board to run it through. This is where the twin/earth is run from, in to the house.
Or you can install another consumer unit, which will need a 'tails' feed to it from the incoming mains feed - obviously, on the house side of the meter circuit.
But AFAIK you are not now allowed to touch this stuff, without being a qualified sparks?
Good/improved earthing is also said to improve Naim kit.
Forum rules preclude some aspects & general discussions on this topic - I would find a decent sparks and discuss things first, as the words in your post perhaps suggest a lack of appreciation of what's required (no disrespect intended).
Posted on: 24 February 2008 by longmanjon
no all comments are appreciated. i mainly wondered if there was any better benefit to either using the current mains or using a separate rcu
