Hi-fi that changed the world.....or transformed your system
Posted by: davewarehouse on 23 June 2002
If you had to name one product that, in your opinion, has made more difference to the hifi industry, the secondhand market, or merely your own system...what would it be?
No doubt the Linn LP12 and the associated shift in system make-up in the 70's will be it for many, the Naim NAP250 as the first high end tranny amp for others, but I'm sure far more controversial and juicy products are in the minds of some of you.
Mine....The Nait 1...not for transforming my system or for changing the world of hi-fi but for.........Netting that jammy bugger on E-bay over £200!!!! At least Dick Turpin wore a mask!
Posted on: 23 June 2002 by J.N.
gets my vote.
It's effect is fundamental and cannot be be replicated by spending the same money on black boxes.
Posted on: 23 June 2002 by Phil Barry
LP12 for me, too, combined with a demonstration of Heybrook HB1s and many other speakers at Pro Musica in Chicago in 1984.
The dem taught me that some components just make me listen, and those are the ones to buy. Other components, which may be objectively better than the ones I listen to, make me want to ask questions. John Schwatrz strikes again.
Incidentally, John told me several times that I should buy an ARO. I finally did, and he was right - besides the LP12, the ARO was the single most important contribution to musical insight that I've ever bought. John doesn't approve of my buying used equipment from private sellers, though, with reason.
The LP12 was simply a revelation. I thought my Thorens 165C was as good as the AR and Rega - later AB comparison confirmed that - but a simple LP12/Basik/yellow cartridge was just plain satisfying , and it iss soemthing f a prereq for the ARO.
Phil
Posted on: 23 June 2002 by Steve Toy
Still my best ever single upgrade. This beast gave me dynamics, PR&T, tune, soundstaging and sheer musical enjoyment in the biggest single leap. Everything else I have done to improve my system was in smaller steps giving me more of the same.
Not bad for £900 (I got a 10% discount for buying it at the Chester Show 2000. Mine is the one that was in the Densen/Ruark CL20s room.)
The QS Ref was big too - I couldn't believe that a rack could make such a difference!
Then you have those subtle improvements like the Music Works ensemble - they make other upgrades worhwhile in the long run.
Steve.
The proof of the pudding...
[This message was edited by Steven Toy on MONDAY 24 June 2002 at 04:40.]
Posted on: 24 June 2002 by Top Cat
Under the LP12 when I had it: Mana
My DNM preamp.
Nordost SPM interconnects.
A dedicated spur.
My VPI 16.5 record cleaning machine (hah!)
All of these gave back more musical enjoyment than they cost. Other significant improvements include:
Neat Petite/Gravitas speakers.
Mana custom stands under above.
QS Reference rack over Mana 6-tier.
Replacing fuses with bigger ones (seriously - ask Roy!)
...and lastly, although I've yet to reap significant rewards, Cara 2.1+ will probably end up on this list as an excellent way to sort out your room and positioning.
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
Posted on: 24 June 2002 by Peter Stockwell
_TC '..'_
"_Girl, you thought he was a man, but he was a Muffin..._"
So how's it going with Cara ?... I used 2.0 and I'm really pleased with results. The funny thing is that iteratively it came up with a solution that Evelyne would have suggested instinctively
Peter
Hi Peter,
Progress is slow due to not having enough time to play with it (and inflexibility on 'er indoors' part) but I am sure it will be very useful when I get a chance to do things properly.
Pity the materials' definitions provided aren't all that comprehensive...
TC '..'
Posted on: 24 June 2002 by Alex S.
Leaving equipment aside, the four best are:
RPG Foam; Mana; Mains Spurs; Joints.
Alex
Posted on: 24 June 2002 by Nigel Cavendish
cheers
Nigel
Posted on: 24 June 2002 by DAVOhorn
A life changing product, easy
My ACR Eckhorn horn loudspeakers.
Utterly breathtaking performance.
I love em to bits.
regards david
Posted on: 25 June 2002 by Goose
Well Tempered Reference, simply the best source I have heard, regardless of format
Goose
Posted on: 25 June 2002 by Naheed
poops all over Fraim
naheed...
poops all over Fraim, oh and 15A fuses !!!
naheed...
Posted on: 25 June 2002 by Laurie Saunders
Mains fuses (getting rid of them) along with associated mains upgrades)......gives true meaning to the over-used term "high end"
Laurie S
