Question about Naim Power Amps and power...
Posted by: Top Cat on 26 January 2004
Hi folks.
Just read the topic somewhere down below about someone's active 250s shutting down. I don't have active 250s - just a single olive 250 - and I'm intrigued by this whole shutting down business.
I assume it's related in some way to the current demands placed on the amp by the speakers, and also a function of the temperature of the amp. However, over the weekend I was fortunate enough to have the house to myself and the knowledge that the neighbours were out. I have a drumkit upstairs, and I know the sorts of volumes I can get out of that. Although the volume I was playing at wasn't quite as dynamic, it wasn't far short. However, the 250 never got any more than slightly warm to the touch, even at eye-blinkingly loud transients.
My speakers are 90db efficient, 4 ohm load, and my room is 18'ish by 15'ish, with a 10' ceiling or so. That doesn't sound like a hugely efficient situation, though saying that it's obviously not hugely inefficient either - kinda the 'Baby Bear's Porridge' of room/speaker efficiency.
So, it's difficult for me to comprehend what sorts of levels some guys must be playing their systems at to cause the 250 to cut out - I suspect I'm nowhere close, even at those deafening volumes.
Though I am happy with my system, a few people have suggested I change from my 250 to 135s to match with the 52/SC. I've always wondered why - any qualitative improvement must be small if the amps are similar in design and if my 250 is powerful enough already. I'm sure this would change if I had some 'pig-of-a-load' speakers such as Apogees or Saras, but I don't, and I question what a bigger amp would bring when I'm unaware of any distortion or limit within the realms of normal, everyday-to-pretty-loud listening.
If my 250 is able to do this with my speakers & room - is there much point in (say) a pair of 135s, a 300 or even a 500? As someone who lived quite happily with a 23wpc amp with these speakers and achieved superb dynamics before, I'm not so convinced the power has much to do with it, rather believing that the quality of the circuitry and power supply make much more of a difference at any given volume level...
Monday afternoon musings... Smile
John
Posted on: 26 January 2004 by Laurie Saunders
A pair of 135s sound far superior to a 250 IMHO.
It is oversimplistic to assume that a 135 is just half a 250, with its own power supply..
Laurie S
Posted on: 26 January 2004 by Top Cat
Fair enough, but *how* is it better - timing, speed, bass depth, warmth/coolth, clarity, imaging, what?
And is a 250 'far superior' based on something to do with its power handling, which in my case might not apply, or some other thing?
Not wanting to be obtuse, just interested...
John
All of these
More delicate, cleaner, more dynamic, less
" coloured", deeper cleaner bass, more open....I could go on
A number of people whose views I respect, say they prefer SBLs driven passively by a pair of 135s to active drive using 2x 250s, if that puts it into some kind of context
Just comparing (paper) power output misses the point
etc
Laurie S
Fair enough. Not planning any upgrades, though, maybe by the time I get the itch again 135s will be dirt cheap... then again, maybe no'...
Still intrigued by 'why' 135s should be that much better than a single 250 in a passive installation, as I always thought the differences between them were mainly the single channel with its (obviously) dedicated PSU and the presence of a fan... correct me, someone...
John
Posted on: 26 January 2004 by Paul Gravett
2x135 v 2x250
Just to confirm what Laurie said about these amps. I used to have an active 2x250/SNAXO system driving SBLs. It sounded very good indeed and I always thought there wouldn't be much to choose between it and 135s.
Then the chance came to buy a pair of the monoblocks at a very reasonable price. I figured it was worth the gamble cos I could sell them on again if need be without much loss.
No chance! I was (and still am) astonished by just how superior they are to the 250s. Some have said they prefer an active SBL system with 250s to a passive-135 one, but I cannot agree. The 135s bring a weight, solidity, coherence and lack of strain that the 250s could only hint at.
In defence of the 250s, though, it must be said that one of them was 10 years old and therefore in need of a recap. The other one was actually of earlier manufacture but had been recapped in 2000. How much later 250s would measure up, I don't know, but I would be surprised if they equalled the 135s level of performance.
Paul
Posted on: 26 January 2004 by solid state
[QUOTE]Originally posted by Top Cat:
Is there such a word as "coolth" - if not there should be !! Wink
Posted on: 26 January 2004 by Paul Ranson
The NAP250/NAP135 (and I presume the current equivalents and up) will shut off if you take too much current. This is the regulated PSU shutting down and it might only take out one channel. The cure is to turn the amp off, pause, then on. The current level at which this trips is adjustable, so over the
years it may have drifted leading to premature interruption...
All the Naim amps I know of have a thermal switch in the mains feed and in contact with the case. Get it too hot and the power is cut. Always both channels. The cure is to switch off and wait for the case to cool. I think there are tolerances on the thermal switches that sometimes work the wrong way for people with difficult loads and demanding levels.
So if your amp never gets really hot and never trips on the intro to 'Tiger Man' then that's excellent. But a pair of NAP135 will still be better...
Paul
Posted on: 26 January 2004 by Derek Wright
250 vs 135s
The 250s promised to deliver something ie they hinted at what was possible - the 135s actually did deliver the promise.
Derek
