Requesting help from the Foobar Helpdesk (Courtesy of Patrick)
Posted by: Hot Rats on 22 June 2010
Hi Patrick
Foobar is doing well for me. You're quite right in saying that you need to be meticulous about metadata!
Just a couple of things that I still haven't worked out ...
1. Using the DarkOne skin, how can I skip further into the track that is playing? When I did this using the default skin it took ages to start playing again so some advice on buffer settings would probably be helpful.
2. When I scroll down my list of albums when making a selection using the downward cursor key, it takes me through each track on each album. Is there a way to scan through just the albums and not the individual tracks.
Posted on: 22 June 2010 by pcstockton
see "help" thread. I figured it might be good to have everything in one place for easy reference.
-p
