HiCap on Nait 2
Posted by: guy batey on 29 October 2002
Is it possible to add a Hicap/FlatCap to a Nait 2?
There's the "turn into pre-amp" option, which I assume means the pre-amp section can then be powered separately by a power supply. Can this be done while still keeping it as an integrated?
Posted on: 29 October 2002 by Justin
I thought about doing this to my nait 2, way back when. But, it would have been a lot of work, and probably not worth the effort.
It's too bad really, because the nait 2 is the favorate integrated of many on this forum, but it cannot really be improved. It's pretty good on its own.
judd
Posted on: 29 October 2002 by Craig B
The installation of the NAIT2 pre-amplifier conversion kit disables the amplifier section and uses the internal power supply for the pre-amplifier section only*. The external DIN connects signal +ve, -ve and ground and is not intended for 24VDC in.
The mod is reversible, however, money would be better spent on a pre-amplifier upgrade if one is looking for a musical performance gain rather than just the ability to drive more difficult speakers to higher levels in larger rooms.
The NAITs perform well because they are well balanced, integrated designs.
Craig
*It is possible to leave the amplifier section in circuit but this is not, to my knowledge, the approved method.
