Weiss DAC 202
Posted by: J.N. on 12 November 2010
A friend brought over his Weiss DAC 202 yesterday for a few of us to have a listen to on my Naim 500 series/SL2 system.
Fed from lossless files on a MacBook with a FireWire connection, it sounded promising with a standard RCA to DIN i/c from Flashback Sales.
Then we tried my RCA to DIN Hi-Line, and the 202 came to life. Very impressive indeed.
This is one gorgeous sounding DAC. The ultimate accolade in the digital world is often 'analogue sounding', and this baby surely is. It produces a beautifully smooth, spacious, organic sound with loads of detail.
Comparison with my Naim triple-five CD player was inevitable. I thought it had the edge, but it was pretty damn close. The 202 is priced at around £4.5k, so that makes the Mac/DAC combo relative good value, with of course all the operational benefits of computer based music access and replay.
John.
John.
Posted on: 12 November 2010 by Plinko
Did you try the headphones with it?
Posted on: 12 November 2010 by tonym
Yes, the 555 had the edge but nevertheless the Weiss sounded remarkably good, and given the price differential is excellent value and a very flexible but of kit to boot.
The Weiss features two different filter settings, swappable via the remote on the Fly; one setting was clearly preferable to the assembled, being clearer and livelier, but I suspect there might be over-bright recordings that would be tamed by the less favoured one.
Thanks to John and pal for an interesting afternoon.
Posted on: 12 November 2010 by J.N.
quote:Did you try the headphones with it?
No - but the owner reckons it's a very good quality h/p amp.
John.
Posted on: 12 November 2010 by gone
The 202 is a nice box. Did it have the edge on hi-res files?
Did you use Naim-ripped CD files, or ripped on the Mac with e.g. EAC/dBP?
Thanks for the report
John
John
Posted on: 12 November 2010 by james n
A very nice DAC. Thanks for the report John. Hope all is well with you
James
James
Posted on: 12 November 2010 by js
Was this yours, James? If so, we know it was well fed.
quote:Originally posted by js:
Was this yours, James? If so, we know it was well fed.![]()
Nope - I'm more Scot than Swiss these days
Posted on: 12 November 2010 by AMA
Thanks for the post, John. It would be very interesting to hear from you on how does DAC202 stand against nDAC/XPS.
Posted on: 12 November 2010 by Joe Bibb
Hi John,
Good write up, thanks for your kind comments.
I had a great day, thank you. The time went so quickly always a problem when you are enjoying some tunes. I would add the following observations:
The 555 has been back to Naim and sounded much better for it than I remember from hearing it before. Tony said that his has also had the same treatment with similar results. It would be interesting to know exactly what has been changed.
Mac Rips were ALAC ripped by a combination of iTunes and XLD. We tried music players and both Pure Music and AyreWave sounded better than iTunes, with AW having the edge. But PM has better integration with iTunes and full remote control. AW is a free beta version, is a small application and works very simply. It sounds superb in Memory play/Hog mode.
Comparing them was interesting it was soooo close. I thought the 555 had a slight edge on a couple of tracks in terms of precision, however on some vocals I found the 202 marginally preferable, but it really was a case of very happy listening to either. A point made perhaps by the fact that we then played a mixture of rips or CDs depending on what was handy. Differences in CD pressings/masterings (and cables as it turned out) were much greater.
The headphone amp is of high quality with variable output settings it will drive my AKG701s quite happily on the top setting. I understand others have enjoyed Grados with it on a lower setting.
Another really enjoyable part of the day was listening to John's other system - Mac/Lavry DA10/NaitXS/SBLs. Having downloaded AyreWave to that we proceeded to compare with bare iTunes, again AW was an improvement this time via optical. I think a HiFace would improve it further, but that system is outrageously good. It just works. The combination of room and synergy that it seems to have, has to be heard. It's one of the most engaging systems I've heard at any price.
Thanks again John, and good to see you Tony.
Joe
Joe
Posted on: 12 November 2010 by JonR
Indeed - a system in which SBLs actually sound good...!!
Cracking amp, that Nait XS.
Posted on: 12 November 2010 by George Fredrik
In the old days I had two sets of amplifiers that drove SBLs well.
Firstly 52/200, and later replaced with Nait 5i.
At the time I had some reservations about the 52 [though not the 200, which was not over faced with a 552 in front] and I think it is true with hindsight to say that the Nait was less intrusive as a replacement. I had no reservations about the Nait 5i ...
I have never heard a Nait XS as these days I make a point of not listening to sets that are more expensive than I would be willing to purchase, unless invited to a friends house!
Jon [R] you heard the old big set with 52 in Hereford, and so did John [JN], and only Frank F [at least from folf of this parish] ever heard the Nait 5i filling the big footprints of the old set driving my somewhat unusually configured SBLs. Honestly the new series of black cased amps is a great step forward over the Olives in my view.
My ideal set now would probably be some Quad ESLs with a Nait 5i now - I can dream on over that one!
In those days my recorded music sources were a CDS2 and Rega P3 ...
ATB from George
ATB from George
Posted on: 13 November 2010 by js
ESLs and SBLs. Still 2 of my favs.
I just find it interesting that things are often this close in comparisons. I usually hear significant differences between sources, even if I like both.
Posted on: 14 November 2010 by Right Wing
Hi John,
Did you use the Weiss's pre (not using your 552) ?
Interesting post
Interesting post
Posted on: 14 November 2010 by J.N.
No.
John.
John.
Posted on: 17 November 2010 by Briz Vegas
Just an observation, Naim are very good on their forums. I can't think of many other company that would allow such free discussion on competing products at their own expense.
On the topic of discussion, I auditioned the Weiss 202 but purchased the Naim DAC with Weiss firewire interface for about the same price. My Naim does not have the XPS but it does benefit from an Odin power cord and more (as did the Weiss DAC). They were different sounding beasts in my system and I preferred the Naim source in my otherwise "no naim" system. I do use room treatments etc so my system is very resolving.
Sorry guys, there is no silver bullet, you have to audition a number of DACs to find the sound that is for you.
Posted on: 24 November 2010 by rich2513
Thanks for the review J.N. Very interesting.
I am a fan of the CD555 and am home demoing the 202 hopefully next week. Having discount the Klimax DS on acocunt of it not working in my system I have high hopes for the Weiss.
It's a shame that you didn't try it directly into the power amp.
Thanks for that JN. I am a CD555 fan but am due to listen to the 202 next week at home. Having discounted the Klimax DS because of system mismatch I have high hopes for the Weiss.
It's a shame that you didnt' try it straight into the power amp though.
In all fairness I think you'd be pitching the lower priced Weiss Dac2 up against the nDAC/XPS.
My own comparison of HDX/nDAC/555PS vs. CD555 seems to bear that out as well, given that the former was nowhere near the latter for enjoyment.
Posted on: 24 November 2010 by AMA
quote:I auditioned the Weiss 202 but purchased the Naim DAC with Weiss firewire interface for about the same price.
Briz Vegas, could you describe the sonic difference between SAC202 and INT202/nDAC?
