Hi-cap options with 92/90
Posted by: Boz on 21 October 2001
Having finally replaced my ageing Arcam Delta 70.2 CD player with a Naim CDX (which is currently running in !!) I have the following dilema.
When the CDX was demoed in a dealership I got them to also hook it up to an XPS and then add a hi-cap. The XPS added something (not as much as I expected for £2,000 !!) to the CDX but the Hi-cap really transformed things, much more frequency response at top and bottom.
As I can't stretch to an XPS yet is it worthwhile getting a Hi-cap for my 92/90 combo, will it add much without the XPS and has anyone done this ??
I'm fairly new to this multi-box stuff as used to have a Nait 3 and have recently upgraded to the 92/90 combo so any advice would be helpful.
I'm likely to buy the Hi Cap secondhand, should I also consider a used Flatcap ??
Ps I'm using Naim speaker cable with Royd Abbott speakers ![]()
