Question Regarding NAT 03
Posted by: lp12 on 16 February 2004
Does anyone know if the NAT 03 tuner (now discontinued but available used) has the ability to be controled from a remote?
Does it even have any pre-sets?
I have a Quad FM4 now but fancy being able to at least see whats on a couple of stations from the couch!
Adam
Posted on: 16 February 2004 by blythe
The NAT 03 cannot be controlled by remote and does not have any pre-sets.
It does sound rather good though :-)
Martin.
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
Posted on: 16 February 2004 by lp12
Drat! thank you for info.
Anyone know if a Rega Tuner will work with a Naim remote, or any other tuners that work with a Naim remote....
Does a Naim remote even have facility to control a tuner?
Adam
Posted on: 17 February 2004 by Jay
A Rega Radio isn't a patch on a NAT03. How can convenience rule when you obviously own an LP12 Wink
Jay
Posted on: 17 February 2004 by Basil
There is a remote control available for the FM4.
A pointy stick!!
Posted on: 17 February 2004 by lp12
Very Funny.
But Seriously, how much do those monkeys cost that some invilids utilize for various button pushing tasks?
Could be a solution to all my remote needs, including the LP12!
Smile
Posted on: 17 February 2004 by Arun Mehan
What about a Nat 05? It has remote capabilities but I think the remote comes with the Nait5 or pre. But you could probably buy a Naim remote or any universal unit.
Posted on: 18 February 2004 by Rico
Basil
there's an alternate form of remote for the FM4 or '03 - a Looo-ong interconnect. Place the tuna by your chair, no need to get up to change the station. Simple!
Rico - SM/Mullet Audio
PS - don't forget to extend and reconnect your antenna feed.
Posted on: 19 February 2004 by blythe
The NAT05 would be the way to go - with remote and also, I believe, pre-sets.
